sativaman84
- Oct 14, 2004
Was looking to purchase/build an external watercooling kit as first watercooling attempt since i'm a vagina and am scared to put everything in the case.
I've seen the EXOS II and like that, especially since it will mount nicely with my v1000 lian li. But seems like the whored out store brands arn't always the best solution. I also have some dangerden/swiftech 1/2" diam blocks and some dd rads so i'm considering throwing together external box but not sure where to start as far as building it goes.
I've currently got:
AMD 4600+ X2
DFI sli-dr
2x bfg 7800gtx
2gb samsung pc3200
2x 36gb 15k u320 seagate
600w OCZ PSU
Lian Li PC-7323A
or can use my Lian Li v1000b
Anyways, ideally i'd like to get a clear plastic/acryllic box that I can run everything in and have two hoses coming out. The current equiptment I have is all 1/2" diameter but from what i've seen and read it's pretty thick and takes up a lot of space. How much of an advantage to you gain from from the thicker tubing and being able to move more water?
Also if anyone knows any prefabricated boxes that would do the trick for mounting the hardware links would be great as i'm just trying to plan out something now before I order the box and other accessories. I have most of the wc blocks already.
Thanks, John
I've currently got:
AMD 4600+ X2
DFI sli-dr
2x bfg 7800gtx
2gb samsung pc3200
600w OCZ PSU
Lian Li PC-7323A
Thanks, John
