external usb adapter for internal wifi card ?
Discussion in 'Networking & Security' started by oldy, Dec 30, 2018.
  1. oldy
    oldy [H]Lite
    70
    Dec 11, 2015
    as the title suggest i am looking for external usb adapter to convert internal wifi card i already have to work externally via usb ?
    somthing like this one :
  2. TechLarry
    TechLarry Can't find the G Spot
    29,499
    Aug 9, 2005
    There has to be a gender changer for that. I need to see the inside of that connector though.
    All kinds of stuff exists:
    This place sells these Hobby Box connectors.
    You could mount it in a small box for protection and use a connector.
    https://www.te.com/usa-en/products/...-connectors/usb-connectors.html?tab=pgp-story
    I'm sure they are on Amazon as well.
    But, unless you are doing it for the fun of doing it, this would be cheaper:
    $9.99 on Amazon.
    FNtastic likes this.
  3. FNtastic
    FNtastic [H]ard|Gawd
    1,097
    Jul 6, 2013
    Did you say I can change my gender on amazon for $9.99? For that price, it might be worth trying. They have a good refund policy!
