external sound card options.
Leright
I have an A8N32-SLI mobo and I already have SLI 7800gts. That means my only non-pci-e slots available are between my video cards, and that space is currently occupied by a bunch or cables that can't go anywhere else, plus I don't want heat to be a major issue. So my only option for sound card upgrades is to get an external card. What external USB based audio solutions are there? I would like to spend no more than 150 bucks for the audio. So, what would you recommend? I would like something similar to the x-fi or audigy 4 in quality. I am aware of the extigy, which is based on the audigy 1, but I would like to go higher end than that. Any help is greatly appreciated.
How about upgrading the cables to some long round ones so they can go somewhere else?
well, the cables are the audio cables that connect to the motherboard, and the cable must be routed between the video cards. However, if I replace the sound card, then those cables will no longer connect there, I suppose. It would still be a tight squeeze.
