lizardking009
- Nov 18, 2005
I have an Adaptec 5085 (8-port external) connected to an EnhanceRack R8-MS with two SFF-8088 cables. The R8-MS is as dumb as a JBOD can be, consisting of an 8 slot hotswap case with two SFF-8088 -> 4 SATA breakout adapters. No expanders or anything else remotely interesting or intelligent.
I also have an Adaptec 5805 card attached to a SuperMicro barebones with 6 hotswap slots. When my boss assembled this box, he used cables without SGPIO so the SM backplane is as dumb as the EnhanceRack. There's no enclosure management.
Here's where it gets odd:
5085: in the Adaptec Storage Manager, it shows 8 drives connected. They're all listed under the heading "Direct attached". Each drive is assigned a PHY number. The PHY number does not correspond to the drive slot. However, if I get the device properties, it indicates the SCSI ID number which does correspond to the correct slot. ARCCONF provides similar correct information. The BIOS provides the PHY numbers.
The Adaptec manual indicates that PHY entries are related to expanders, but as far as I know, I don't have one in the mix at all. There certainly isn't one in the EnhanceRack.
This strange seemly cosmetic defect makes hit hard to tell at a glance which drive on the EnhanceRack is problematic since the PHY doesn't match to the slot.
5805: In the Adaptec Storage Manager, it shows 6 drives connected, 3 to each SFF-8087 connector. Those SFF-8087 connectors show as CN0 and CN1 and under each CN heading, there are 3 devices: 0, 1, and 2. Each device corresponds to the appropriate slot in the case. Perfectly logical.
Can anyone explain to me why the 5085 and 5805 behave so differently with regards to direct attached drives? Can anyone suggest how to make the 5085 behave like the 5805?
Does anyone know if the LSI external SAS or Dell Perc 6/e have the same kind of strangeness with dumb external JBODs?
Thanks.
Thanks.
