Hi everyone. I am lurker but have been here for a little bit.
So, I plan on building a new rig in the somewhat near future, and while I plan on initially air-cooling it (probably for a while), eventually I would like to use liquid cooling with an externally powered and positioned pump and heat exchanger. So basically I am browsing the market for alternatives.
The cooling would be for at least a CPU, GPU and bridges, so talking at least 500W, hopefully more. All over one circuit I think- so need a relatively high head pump. However, if it's really preferrable to split into parallel circuits - I suppose I could swing with that.
Two pre-built kits caught my attention the most and those are:
1. Zalman Reserator XT: http://www.sharkacomputers.com/zarext.html
Expensive as hell, but seems to get the job done and more. One thing that [H]ardForum warned against is the fact that while most heat exchanging components are copper, some are aluminum. But what I was thinking - I know a few people in their CNC shops - so if need be, I can pay for and custom machine the copper parts to replace aluminum. How feasible is that?
2. Koolance external cooling systems. This page basically: http://www.koolance.com/water-coolin...hp?cPath=28_41
Less pricey, but also seems like less powerful (the way the radiator is cooled seems less efficient as it's not a through-flow, plus I believe without the upgrade the pump has less head). But yeah, the much less expensive is in fact attractive.
After reading a few comments here I am basically leaning away from Koolance.
I know a lot of people here recommend the Petra's Tech kits (aka http://www.petrastechshop.com/pecosliel.html) - and I can see how they are good, but again, what really scares me is the way the radiator is set up there. That's also what tilts me toward Reserator - I can swing with low head and even potential corrosion (see above why + copper coatings exist and I can get my hands on some) - but the thru-flow of the radiator is something I really haven't been able to find on most lone radiators (as they seem to be intended to be inside the case and I want mine to be external).
So thoughts and/or recommendations? Anything's appreciated.
