external housing - mac style!
steff79
Hi...
... I bought an Apple iBook G4 some month ago... I love it and it's supersexy.. the only thing that hurts is the limited harddrive space an the fact that the 12'' iBook has no Superdrive option... so I decided to use 2 external devices to reduce the pain. A 120gb Harddrive from Samsung and a DVD Writer from NEC. But all those nice looking external housings are way to expensiv and way to "not looking good with my baby". So, in consequence I have to build my own case with lot's of goodies...
So, I made my plan and decided that the case should be out of MDF (don't know the english word). Unfortunately there was no store in town with MDF <16mm... so the measurements are a bit larger than a thought, but i don't care... yet ;)
What would/should be inside is:
- DVD Writer
- 120gb HDD
- Bluetooth USB Stick (for cellphone, printer, mouse)
- 4x USB2 Hub
I ordered 2 of the cheapest 3.5'' USB2 external Cases and cannibalized them in order to get these things...
Then I start to build the housing... first of all I rounded all edges with an "Oberfräse" (Sherlock calls it "mill to fixture"?!)...
Then I drilled the holes for the DVD Writer...
After that I milled some airslots for the Harddrive and one the backside, and a slot for the DVD Writer. I also added holes for the powersupplies.
Then I primed some of the parts...
The last thing i did so far was to add the mandatorily apple logo an glue the hole thing together...
After priming the case i realisized that i forgot to bondo the slots [smiley=seestars.gif] and gave the hole thing a nice bondo and sanding job (i also smoothed the apple logo an all egdes)... here's the result:
And this is the fastening for the harddrive. I wil glue it in, when the paintjob's done...
The case with it's fresh and new color. unfurtunatly it's not this glossy i wanted it.
And because *everybody* wanted a plastic apple... i did one. And i like it... woohooo!
Here's a picture of the backside with a bunch of electronics, that need to be fixed inside.
All screwed up :)
And here a "family-picture" with my ibook.
That's it... tell me what you think about it.
not bad...I am wondering why you didn't go FireWire instead of USB2 though and "Oberfräse" I think would translate to Router based on what it did...if you are looking for the gloss try using a clear coat and see how it looks after a couple of coats of that
I didn't go for firewire because i was not able to get an firewire-bluetooth-stick :(
It's a bit glossy... but not as much as ih hoped... but i won't change it now... i'm happy to use it now... :)
Use some clearcoat and maybe encase it in plexi.....how about backlighting that Apple logo too? ;) Anyways...
Thats really cool man, good job on the mod.
I like the Apple ;)
And yes, an "Oberfräse" is a router.
nice work, but it woudl be awesome with a nice sleek paintjob + clearcoating to mimic the Powerbook's look ( adding depth to the paint )
otherwise, I like it :D
A really great and useful mod. Like the people say above, the more glossy paint would be nice, but it looks awesome the way it is. Have you thought about adding a fan or something to make sure things don't get too hot?
Ditto on the fan. I bet that MDF is going to insulate and make it a sweat box!
But damn! That is sweet. Nice job on both the look and on incorperating all those items into one box. Looks sweet as hell. I think if you do go back and add a fan, you NEED to do something to light up that Apple logo. I mean, come on! A plexi logo/emblem on the front, all alone, and NOT lit up???? FIX IT, or we revoke your [H] status! :D Nice job though.
ITs also known as MDF in the states by the way which jsut stands for mass density fiberboard I beleive. Anywasys its not exactly smooth smooth so I would have suggest using a nice grain filler first to help with the glossy finish you were going for, still it looks good to me, you made it who gives a damn ;)
Medium Density Fiberboard
