Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Performance wise, the USB drive will be slower than an internal drive. Expect transfers of around 30-40MB/sec. If you can use FireWire, you should, as you will enjoy consistently higher transfer rates and lower CPU utilization.
USB 2.0 has limitations, but they don't affect external hard drives that much. It still takes a while to dump 200GB of data anywhere - go grab lunch or something in the mean time.
