external HDD help
RancidWAnnaRIot
EspantaPajaros
So, i'm looking for a 320 - 500GB external USB HDD..
my question is... which companies are good at external HDDs..
western digital? who else?
should i go OEM?
i would go with a seagate hard drive and an antec mx-1 enclosure. The seagates have 5yr warranty and the antec mx-1 is supposed to be an excellent enclosure (has usb and esata)
i say use a western digital drive with the enclosure stated above, i have a couple of those myself and are great.
huuumm... so you're saying for with an internal harddrive and then get an enclosure.. interesting
Also - I'lll throw this in. If you have a firewire (IEEE1394) port I would definitely consider finding and enclosure that will support that connection over USB. Not sure about external SATA though...
