external hdd enclosure
Daifeichu
Can anyone recommend a good external hdd enclosure. It should have usb/firewire and be able to handle s/pata drives. I prefer 3.5" but 5.25" will do just fine.
Thanks
Depends how long you want to keep the drive and enclosure. If you need it for a temporary amount of time, then get a cheap one off newegg. But if you want something that will last alittle longer may I suggest an enclosure that has a fan in it as to keeping your drive cool. That's important for the longetivity of your drive.
If your lucky you might find someone on here on the forums willing to sell you one.
http://www.hardforum.com/showthread.php?t=929844
