External HD Won't Mount.
Nobi125
I loaded a bunch of new stuff on my external HD, and disconnected properly through Add/Remove Devices.
I'm on a different computer now and nothing happens when I plug the drive in.
I also tried it on my laptop, which it worked fine on yesterday.
I took the enclosure apart to make sure nothing came loose and there wasn't anything obviously wrong with it.
I tried restarting the computer and using different USB ports but didn't have any luck.
When I turn the drive on, it just doesn't start spinning.
How can I fix this issue?
Just tried a different USB cable, no luck.
This really sucks, I put a bunch of music and movies on it since I was going to visit my parents and now I can't access any of it.
