External Hard drive enclosure for external cdrom?
carnag3
Hi, If i use the converter chip from an external hard drive enclosure (to usb) and plug in a cd rom, will this work? thankyou.
Should work fine. Just make sure the drive is set to master or cs
Is the enclosure's internal interface SATA or PATA? If its PATA, you might have to play with the jumpers as swatbat pointed out.
Well All I have lying around is IDE hard drives, the thought was to use that with an ide enclosure... I this still possible?
thanks for comments :D
Now you want to use it with a hard drive? I though the enclosure already had a hard drive in it, and you wanted to put a CDROM in it. PATA = IDE, sorry if that confused you.
Again though, what is the internal interface of the enclosure?
I do not have an enclosure yet, I do have an Ide DVD drive lying around, and a parents laptop with a dvd drive that wont burn... SO basically I want the cheapest method to give them burning again...
also, WOW PATA is IDE??? lmao, I have always wondered what the heck pata is! thanks ha
