External eSATA drive write protected
icehole
I have an external drive I am using for backups with Acronis Home and the damn thing keeps getting write protected.
I can remove the write protection with diskpart only if the drive is open in Explorer and in a day or two it goes back to write protected and Acronis can't save to it.
I did what is outlined in this THREAD and it hasn't helped.
I need HELP!
Yesterday I cleared the read only settings on the drive, Acronis did it's backup fine and I turned the system off for the night.
This morning I turned the drive on then powered on the system and the drive is write protected again. Diskpart wouldn't clear the read only attributes.
I turned the drive off for a couple of minutes and then turned it back on and it is no longer write protected.
I am using WIn 7 Home x64 now. I didn't have this problem with the drive when I was using XP Home 32 bit.
Any ideas other than waiting until Windows has loaded to turn the drive on?
