External enclosure messing up my hd?
GotMyDeal
Hi,
I just got a 3.5" external enclosure for my Maxtor 200g hd, which is pretty new and it works great. The problems is that after I put the hd in that enclosure, I can only browse through on partition out of 2 that I have on that hd... each 100g, so basically what I'm trying to say is that I cannot access half of that hd. What the heck it's going on... can't believe that I probably just lost a lot of stuff of that hd.
Anyone ever encountered this problem, or knows anything about it.. any workaround for this, or is it really my hd gone bad once I plugged it in that enclosure?
Thanks.
Most of those external enclosures run a version of Linux and a few run a version of MS-DOS. It may be possible that you lost your data for good since if it is Linux, it probably didn't use NTFS for it's file system.
