ben johnson
- Dec 30, 2002
I just bought this external enclosure:
http://www.newegg.com/Product/Product.asp?Item=N82E16817145745
It came with a drivers CD but the drivers were made for windows 98. When I try to install the drivers it says "Windows 98 only" and then exits out of the installation. When I connected the device to my laptop which is running Windows XP it said it was installed successfully. How do I access this drive? I cant figure out how to use it. It's not under "my computer" but when I go to control panel > add new hardware its in the list. Also, its connected through USB.
Any ideas?
Thanks for your help.
Any ideas?
