External enclosure for 1.5tb Seagate?
Copyright
I want to run this in an external enclosure but I want to run a higher end enclosure that has some sort of cooling and of course something that will work with the 1.5tb drive. Any ideas?
I don't think that external USB enclosures will have any compatibility issues with yer monster drive. But when you live on the bleeding edge........:D
If you were looking at some kind of NAS, then you might have issues.
A single drive in any kind of aluminum enclosure should be fine. I own 2 no name usb enclosures that I have used with several drives over the last few years with no problems.
Don
The enclosure is eSATA also. I may consider this but found my case has a coulple other HD mounting points inside I forgot about. I might give it a try first.
I am using a vantec nexstar 3 esata USB 2.0 external enclosure for my 1.5TB drive. works fine and temp never goes above 45C. usually hovers around 40.
