External drive for laptop?
mrwill
Is there such a thing as an external optical drive (CD/DVD) that gets data via USB and is powered with a wall plug (ie,not via USB)?
FnordMan
err... why? The 3.0 models can get enough power from one cable and the 2.0 models can get all of their power from the laptop w/ 2 cables.
You may be able to "make" one out of a 5.25" external case and a standard ODD but it'll be huge compared to the slim, portable models.
mrwill
I bought a Lenovo laptop and it did not appear to have enough power to drive an external drive. It had some other problems, so I returned it and the drive. I just wanted to be sure the drive works on the next laptop I buy. Maybe it was a problem with a defective laptop.
iroc409
I have an older slim USB DVD-ROM that I use on occasion to install things with, and it has a wall plug. They are out there.
FnordMan
Random idea that may work: One of the split cable USB 2.0 ones may work w/ one of the plugs hooked to a USB charger (be sure it can deliver at least 1 Amp)
