I have a Seagate 120GB/8MB drive connected via this external enclosure. Is there any more risk involved running this drive 24/7 versus one that is directly connected inside the PC? TIA.
let it run for a good 3 hours and mesure the temp on it
some of the external enclosures do not have good cooling
if the drive is resonably cool (under 105f) then i would say its safe tu run it 24x7
if its running really hot i would say only use it when u have to or get a enclosure with a fan
they cost about $5-10 more
but they are worth it
the 200gb external i have has a fan in it and it runs a grand total of 5f over ambiant temp and its near dead silent
I had an external drive that kept dieing after a couple weeks.
Basically I got it, it worked fine, I moved, the hard drive died, got an RMA, it died, another RMA, it died, etc
Finally I realized that the location I had my enclosure wasn't ventilated well. So after I got my new RMA, I moved the enclosure to where there were no obstructions above or near the sides (ontop of my case) and the drive has been running 24/7 for almost a year.
