External Cooler
Hands down the best external cooler.
http://www.hardforum.com/showpost.php?p=1030608867&postcount=2740
Build your own out of a mATX case, far better performance and one heck of a lot cheaper............:eek:
229,90 Euro for the small one and 399,99 for the big one.
You can read some further infos here.
I've got the Nautilus as well and it's so easy to setup and it's only $150, took me under 30 minutes to put on my cpu. I later added my 8800GTX to the loop with a swiftech MCW60 and it was still pretty easy, but took a bit longer than I thought. Most of the time was for cleaning and putting the heatsinks on the 8800 though.
what does everyone use for cleaning heatsinks/cpu's of thermalt grease?
I use 91% isopropyl alcohol and "Oops" from wal-mart, and lots of cotton swabs.
