Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
how should i power my external case? it will have 2 cold cathodes, 3-6 fans(atleast 3)and a pump(swiftech mcp655) i have an extra psu but i would hate to use a flip switch just to turn on a pump and ideas.
Well you can always run a trigger wire to your external case. Or you can purchase two wireless computer starters... put them on the same frequency so that when you press the start button both machines will boot
Option #3:
Buy an old AT powersupply. They are independently switched, so you don't need a motherboard or whatnot to power it on. A small AT PSU would power everything you need. Hell...you could probably leave it on 24/7 to keep your W/C gear running and but just switch your comp off.
The major reason was simple. Testing and filling. With an external box, you usually have more hose, etc.. so it takes a bit to fill the whole system. Having it connected to its own PSU is a life saver, You are turning it on and off a lot during filling, having it on its own PSU that you can turn on and off at will is a great feature.
There are 2 ways to mod a PSU so it doesn't need to be connected to a mother board... one way is to use a paper clip (you can search the forums for that one) or you can twist one black and the green wire together to jump the mobo connector.
You could always rig it to turn on as soon as you plug it in. That's what I did with mine. I was going to put a switch in for the pump, but what's the point? You'll never turn it off and you don't want to risk it getting shut off on accident.
