Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Here we go, that circle for the fan grill/filter was cut with the dremel circle cutter then sanded down with the dremel sanding rolls then wet sanded. Very pleases with the work, 120mm fan template was also used from moddin.net.
