Yeah, it's pretty complicated. The formula is:I do recall that the rsistance to flow increases a bit with cable length, if I recall? But I don't know the exact formula......there has to be an engineer on here somewhere who could answer that.![]()
(total resistance) = (resistance per unit length) * (total length)
Also, you have to add in the resistance of each connector junction, which is different from the resistance of the wire itself. And if the wires in the extension are a different gauge than the PSU wires, you have to figure out the resistance of each segment separately and add them together. See? Pretty complicated.
(There is a more complicated version that takes into account the resistivity of the material the wire is made of along with its cross-sectional area, but since all these wires use standard AWG sizes, you can easily look up the resistance per length values on an AWG table)
