AlphaModel
- Sep 8, 2005
My current table placement is not really optimal for my sub, it is not located near any corner or wall. It's about 3-3.5 feet/1.2m from the nearest wall. The bass feels a little light, I'm using only 2 bars. Increasing it makes it feel more "boomy" so I moved it to a corner and it was much better very tight and precise.
Anyway, I'm thinking of moving the sub to a corner instead but the problem here is the control center. What type of cable do I need to extend the cable that is connected to it from the sub so that I can have it on my table?
Looking at the connector it looks like a vga monitor cable, would an vga extension cable work?
