Extending FAT32 Partition
ohnnyj
Can a FAT32 partition be extended after Windows has been installed on it? I have a computer at work that doesn't do much more than scan stuff in and has had no need to upgrade to a better OS but it is running out of space on the hard drive since Win98 is only seeing the first 2GB of the drive. Is there a way to get this space back?
Thanks.
Better check to make sure the drive isn't FAT (FAT16) instead of FAT32. If it is indeed FAT32, PartitionMagic will resize it for you.
