Exporting VM Templates
jenuster
Would there be any issues with creating a VM template for an OS on one ESXi host, exporting it, and then importing it to another ESXi host. Basically I want to create a master OS template in my home lab and use it at clients when necessary.
I'm assuming not, but just checking.
Works fine. Just make sure you don't use a hardware version higher than an environment can support. Don't make a hardware v8 template and try to use it on vSphere 4.
