im not sure if the following question fits into operating systems or networking, but i felt safer putting it here
i have about 400 computers, all of which are to be used by students who have nothing but malicious thoughts....so i need to be able to disable the menu bar (File, Edit, View, Tools, Help). ive tried looking through group policy and cant find anything to fit the bill....and also saw a FEW 3rd party programs that said they could do it....but they dont look promising from the networking point of view. i dont care if the menu bar is just dimmed or if its completely gone but it needs to be disabled in some way.
a second problem that im facing is one that seems easier to tackle. in windows xp, you can enable policies to hide the entire notification area (used to be called the system tray...icons in lower right hand corner)....but in 2000 it seems as though theres no equivalent. there are many 3rd party programs for this but once again most dont have the ability to deploy over a network. ive tried taking bits and pieces of the xp adm files to sloppily get something to work but no such luck.
any suggestions are appreciated and ill be able to test any ideas early tomorrow morning. thanks
