Expirencing LAN problems on PC
3991vhtes
Hey guys I have a few LAN problems with my computer.
First off, my desktop doesn't load any web pages.. and if it does, it does it very slowly! The only things that really worked are Steam, AIM, and MSN. OCN would work a few times, but was really unreliable (sometimes it wouldn't work)
I thought it was the cable (100 foot) but I am typing this on my laptop, with the cable plugged in and the WiFi off. It works on my laptop, and my brother's computer with a Netgear hub.
I tried a LAN card, but that didn't work. Why would _just_ my computer not work with the net on a LAN cable, but everything else does?
Any help to get it running again would be awesome, thanks
are you sure the computer is pulling an IP from the same range as the others in the house?
It's not, but I changed it to automatic instead of manual, trying it out now
If MSN, AIM, and steam work it's not the cable. It's the browser. If your on IE then switch to Firefox and try it... if your on Firefox then scan your computer for viruses and spyware.
There was an IP config error. It works just fine now and I set it to auto config. (In Windows)
