This is starting to make me ill. This is how bad this problem is, how persistent it's been, and how absolutely helpless I am after 8 or so months trying to fix it.
If anyone out there knows the magical solution, I might just consider them God.
Situation is as follows: I had no problems up to and including the 185.85 Forcewares. Everything worked hunky dorey.
Ever since then, and that's about June, I've had this particular problem and I feel like even if I bought an entirely new PC, I'd still get this issue, that's how ingrained it's become. Everything I try fails, and that's a lot of attempts.
It's driving me crazy, and refuses to be resolved.
Ok, the problem...
I have a 42XV505D Toshiba REGZA HDTV. I also have an Iiyama LS902UT 19" CRT monitor.
The monitor is my main display for PC use, but I use the TV for gaming at HD resolutions.
However, no matter what I do, since the 185.85s, using Multiple Displays in the Nvidia Control Panel has become an absolute nightmare. I right click on the desktop, and choose Nvidia Control Panel, and instead of it coming up as a dialogue, whatever monitor I am on goes into standby, the other one turns on and gives me the dialogue. Basically, Nview use has become impossible and unpredictable.
Now, one significant factor is that I am on an SLI system, and I have noticed far less problems when I disable SLI or one card. In fact, it all seems to work ok under those circumstances. But when I turn on SLI or re-enable the card, the system becomes beyond volatile.
As you may expect, this is not wholly useful. I need the full power of both cards, AND smooth and predictable use of Multiple Displays. I've tried different SLI bridges, and switching the 2 cards around, but that didn't help.
I need: the current drivers for the performance gains
Both cards in SLI so I have full performance
Multiple Displays/Nview to behave itself completely so I can use it it rather than watching in horror as my displays blink on and off in complete random and aggressive tones. Oh yeah, that happens too.
Any wonderful suggestions?
Ok, the problem...
