It's Wiindows xp and everytime I am half way done with an application the "alt-esc" brings up a different window. Anyone know how disable alt-esc??
pillbub said:Is there anyway to change windows keyboard controls? I am trying to do make it so app's won't close if you push Alt-Esc.
How do you change windows key controls....specifically alt-esc??
pigster said:Install a keyboard hook: http://support.microsoft.com/kb/q226359/
mikeblas said:That's the right way to skin this cat.
Meanwhile, why do you not want ALT+ESC to do its job, pillbub?
pillbub said:Its Everquest 2 spells.
