Expert help regarding PS3 and USB Sticks
Subtle
Hi guys.
I have this problem, i have a Sony Micro Vault Click 16 GB USB Stick.
The stick works fine on a PC no problems.
However when i plug it in my Playstation 3 nothing happens.
I have tried formatting to FAT32 several times, even on different PCs
(FAT32 seems like only option too)
I then bought a cheap 2GB stick and that worked fine with the PS 3.
I have talked with Sony Live support twice, they told me to send a mail to the Playstation support unit, which i did.. and they didnt reply. it has been 2 months.
And one other thing too, if I plug the 16 GB into the PS3.. and then plug the 2GB USB Stick (which is corsair btw). The PS3 will detect the 2 GB as `USB Device (DT-101 II) as opposed to `USB Device (DT-101 I) which should indicate that the PS3 does see the 16 GB device in some way.
Any ideas ?
