rockdude14
- Feb 28, 2003
I've got a perc 5i with 4 750 gb spinpoints in riad 5
I'd like to add 2 more drives to it but had some questions
newegg has a 10% off all hard drives this weekend so I figured nows a good time to do it
the first problem is they dont sell the drive that I used for it initially
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152100
they do however have this
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152099
the only difference seems to be old drives have 32mb buffer compared to these have 16mb
they also have this
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152118
but i dont really want to pay 90$ compared to $65
do you think the 16mb of buffer will have a big effect on speeds
speed isnt the important part of this array
but I want it to perform as good as it can
also any guestimate on how long it would take to expand from 4x750gb to 6x750gb?
thanks
they also have this
thanks
