exos power
chuckm1020
tommorow i will be refilling my exos when i add on my gpu block. i lost the jumper to jump the power, so the only way i can turn on the exos now is to turn on the whole comp. and when i refill it the processor and video card will be on but there wont be water going through until the pump starts circulating it. Is this safe!!!???
you can use just a regular wire to do the jump just jump it across the same two wires you would use when using the one that came with the exos, i just use a old wire from a molex connector i tore apart. but no it's not safe, so just do the jump with some other wire you can get your hands on
Paperclips are your friends:D Thats all the koolance thingy is. A wire perhaps...but a paperclip is just as good.
