Exos-2 pump cavitating terribly.
N3mi5is
I've had my exos-2 for almost a year, and I went out of town for a few days and forgot to turn off my pc, now when I got back, the pump is cavitating really bad and is making a loud noise like it's not going to last much longer. Is there a way to try and bleed the air out of the system or will I be replacing the pump here soon?
You need to start adding more coolant to the res just like you did when you first filled it. check all the tubing connections, give them just a little extra twist to make sure they aren't pulling air in.
I topped off the coolant a few days ago, and the pump just now quieted back down.
Weird.
