Excruciatingly slow BD file transfer
Activate: AMD
I'm trying to transfer some files off of BD using a new LG UH10LS20 and it is extremely slow. Specs state 10x BD transfer rates, which should be ~40MB/s max. For some reason I'm running at 2.5MB/s, which means for a 40gb BD disc its going to take hours. This is ridiculous and never had this issue with my old GGC-H20L
Doesn't it have a riplock to keep it quiet?
I know my CH10LS20 did before I flashed it.
your sata controller... it's not in IDE/Enhanced mode, is it?
I'm not sure, how do I check and/or disable it?
Download Nero CD-DVD Speed 4.7.7.16 and run the test on a single layer BD. Then take a look at the graph when it's done.
