By default, the internet email recieve connector will only recieve mail destined for your authoritative domain. There are ways to change the security to make that connector an open relay but that takes a trip to the EMS and some CLI. Did you step into this issue or just setting up? What will working with this connector affect? What is the desired behavior?
Typically Postini's reinjections are limited by IP security, i.e. restricted to ONLY apply to their servers. Having that security hole apply to the Default recieve connector did exactly what you feared, create an open relay. I haven't seen the Postini commands for integration with Exchange 2010, but I would image that you would want to leave the default internet connector alone and create an additional connector, limit it via IP to your Postini system block, and open up relay via that command they sent you. Personally, I've never had very good experiences with Postini and Exchange, so I've moved on to other services that either have better integration or do not require this type of integration.
Cool, thanks for the info. Yeah, I am not a fan of Postini, but unfortunately we are stuck with it for now.
You should only allow smtp inbound from Postini IP addresses in your Firewall solution then.
