Excel/Outlook ?
nate77
Work just upgraded to office 2010,when I start to type an email address emails will pop up to chose from,But when I send an email from excel and the window pops up it won't remember the previous emails and this is driving me nuts,cause its a drag digging threw address book.
Any way to get outlook to remember email addresses when sending from excel?
Thanks nate.
Works on my pc. That outlook email history file is an .nk2 file usually called outlook.nk2. Outlook 2010 stores that file a little differently but there's a nice command you can use to import the nk2 file from older outlook programs into 2010. The file will need to be in the users roaming folder and needs to be named outlook.nk2 if it isn't already. Once it is in place go to the run dialogue box on the start menu and type in "outlook.exe /importnk2" without the quotes and execute. Hopefully excel will then access the history file properly.
