Hi guys, I need that, let me show you, it will be easier to undertand.
A 1
A 2
A 3 6
B 2
B 5 7
C 1
C 1
C 5
C 3 10
So, basically, I have A LOT of different names in the columns with the letters.
I need Excel to look at column A and sum the values on column B, as long as the value on A has not changed. If it did, it should stop doing the sum, copy the value at C column and start again.
Can this be done with a function or it requires programming a macro?
Anyone can help, whether it is by a function or programming?
Thanks a lot!
A 1
A 2
A 3 6
B 2
B 5 7
C 1
C 1
C 5
C 3 10
Thanks a lot!
