There has to be a simple way to do this.
worksheet 1:
It has two columns with over 1000 rows in which the value in A1 will match with B1, A2 to B2, etc
worksheet 2:
It has one column with mostly the same information as worksheet 1's column B
I want to look up information in worksheet 1 column A, and copy it to its corresponding B value in worksheet 2.
If you must know why, it's because worksheet 2 has the absolute correct values of column B, whereas worksheet 1 is a compilation of various sheets.
worksheet 1:
worksheet 2:
