EvilAlchemist's folding stats web page
AMD_Gamer
http://webpages.charter.net/evilalchemist/
Ok how do i make a badass stats web page like this? it looks like a F@Hmon output but all your clients are pooled together into one page?
I have been having F@Hmon at my house and my GPU box at school put the simple web page into my dropbox and using dropbox to monitor my clients.
AgrFan has also asked for a guide on how to set that up as well.
I am trying to get one put together but I have been working almost every day.
I will get something put together as soon as I can.
I have the guide about 1/2 way done so far since we have been slow at work.
You are correct, it is just Fahmon's "simple webpage" with a few modifications to the template that alter the background color and the order of the columns.
Then a ftp batch files uploads the file every thrity minuntes to my server.
When I get it done, I will get it to King_N to post on Hardfolding Guide Section.
This will be good.
It will give me something to keep an eye on the farm while I'm gone for the holidays.
sounds great
Okay ... Here is the guide you guys requested.
I have tired to make it as clear as possible, but if you think something needs to be explain better or use different terminology, just let me know
I will also let King_N know so he can post it on HardFolding.Com
Client Web Status Guide using FahMon
  • Setup FahMon (Based on 2.3.4v Configuration)
(This guide assumes all your clients are already setup and monitored by Fahmon)
  • Go to your Fahmon Install directory and Create a New Folder named "Upload"
  • Open the Preferences (Ctrl +P) and select the "WebApp 1" tab.
  • Select the "Export Simple Web Page Function" & name the file fahmon.html
  • Save fahmon.html file in the new "Upload" folder created a few steps earlier.
  • Under the "Monitoring Tab" - set the "Auto Reload Clients" interval to 10 minutes
  • Under the "General Tab" - enable "System Tray Icon"
  • Now Minimize FahMon (Will come back to it later)
  • Setup FTP Upload
  • Create a new txt file inside the Fahmon\Upload\ folder and name that file ftpupload.txt
  • Copy the following code into the upload.txt file
    Code:
    OPEN my.ftp.com
    mylogin
    mypassword
    binary
    MPUT fahmon.html
    BYE
  • Change the value of "my.ftp.com" , "mylogin", & "mypassword" to your server & login information.
  • Change the value of "MPUT fahmon.html" to the location of your html file from Section 1 - Step 4
    (Example: "MPUT Z:\Fahmon\Upload\fahmon.html" or "MPUT C:\Program Files\FahMon\Upload\fahmon.html")
  • Save Txt File and Close
  • Go the your Windows\System32\ Folder and create a new txt file
  • Copy the Following Code into that file
    Code:
    ftp -i -s:C:\ftpupload.txt
  • Change the value of "C:\ftpupload.txt" to the location of the "ftpupload.txt" you created in Section 2 - Step 1
    (Example: "ftp -i -s:C:\FahMon\Upload\ftpupload.txt" or "ftp -i -s:C:\Program Files\FahMon\Upload\upload.html")
  • Save File as FTP.BAT in the Windows\System32\ folder and close file
    (Another option is to save the txt file and rename it to FTP.BAT)
  • Setup Verification
(At this point, we need to verify the steps were completed successfully up to this point)
  1. Navigate to the FahMon Upload folder and open Upload.html
    All your clients should be listed on that page. If they are not, Bring Up FahMon from the system tray and hit "F6" or "Menu Bar - Clients - Reload All"
  2. Navigate to the Windows\System32\ folder and run FTP.BAT, then verify that the html file has been sent to your web server.
    (Example: http://www.evilalchemist.com)
  3. Once you have verified that FahMon is creating the fahmon.html file and FTP.BAT is uploading the file correctly, move on to the next section.
  • Create Scheduled Task
  • Congratulations - You Are Done
  • You Fahmon Client Status page will update every thirty minutes to your server.
  • Make sure you have Fahmon running in the system tray at all times or the scheduled task will just keep uploading the same html file.
  • Advanced Option - Template Customization
  • Some Users may wish to change the layout of the web page created by the client.
  • The template file is located at "FahMon\templates\simple_template.html"
  • Template Options & Help is located in "\Fahmon\docs\TEMPLATE_SYNTAX.txt"
  • If you wish to use my custom template - here is the code
    Code:
    <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
    <head>
    	<meta http-equiv="content-type" content="text/html; charset=utf-8" />
    	<meta http-equiv="Pragma" content="no-cache" />
    	<meta http-equiv="refresh" content="500" />
    	<title>UserName Folding@Home Server Status</title>
    	<style type="text/css">
    	TD {
    	padding:2px;
    	border:1px solid #000;
    </style>
    </head>
    <center><font size=+2 color="#FF0000"><!--tpl_static @USERNAME@ -- Team: @TEAMNUMBER@ [H]ardOCP tpl//--></center></font>
    <body bgcolor="#000000" topmargin=0 bottommargin=0 leftmargin=0 rightmargin=0 marginheight=0 marginwidth=0">
    			<div align="center">
    		<table style="border-collapse:collapse;border: 1px solid #000;font-family: Courier New; font-size: 10pt">
    			<tr>
    				<td colspan="3"><font color="#FF0000">Windows / Linux Systems</font></td>
    				<td colspan="3"><font color="#FF0000"><!--tpl_static @_Last_updated:@ @UPDATE_TIME@ tpl//--></font></td>
    				<td colspan="2"><font color="#FF0000"><!--tpl_static @_Total_PPD:@ @TOTAL_PPD@ tpl//--></font></td>
    			</tr>
    			<tr bgcolor="#CCCCCC">
    				<!--tpl_static <td><center>@_State@</center></td>
    				<td><center>@_Progress@</center></td>
    				<td><center>@_Name@</center></td>
    				<td><center>@_ETA@</center></td>
    				<td><center>@_PPD@</center></td>
    				<td><center>@_PRCG@</center></td>
    				<td><center>@_Credit@</center></td>
    				<td><center>Core</center></td> tpl//-->
    			</tr>
    			<!--tpl_loop <tr>
    				<td bgcolor="@STATE_COLOR@"><center>@STATE@</center></td>
    				<td><center><FONT COLOR="#ffffff">@PERCENTAGE@</font></center></td>
    				<td><FONT COLOR="#ffffff">@NAME@</font></td>
    				<td><center><FONT COLOR="#ffffff">@ETA@</font></center></td>
    				<td><center><FONT COLOR="#ffffff">@PPD@</font></center></td>
    				<td><center><FONT COLOR="#ffffff">@PRCG@</font></center></td>
    				<td><center><FONT COLOR="#ffffff">@POINTS@</font></center></td>
    				<td><center><FONT COLOR="#ffffff">@CORE@</font></center></td>
    			</tr> tpl//--></FONT>
    		</table>
    	</div>
    </center></body></html>
  • Edit the "UserName" in line"<title>UserName Folding@Home Server Status</title>" to your F@H User Name
  • If you wish, you can edit "Windows / Linux Systems" in the line "<td colspan="3"><font color="#FF0000">Windows / Linux Systems</font></td>" to state which clients you are running.
    (Example: Windows GPU2 Clients or Linux SMP Clients or any other text you wish)
    (Warning: Too many Characters in this line *may* mess up the table spacing)
  • Once you are done making modications, save the file, go into Fahmon & Reload All Cleints and check the new fahmon.html file inside your FahMon\Upload\ folder.
  • Advanced Option - Multiple Client Locations
(If you have clients at different locations or different networks)
  • Repeat this guide, but in Section 1 - change fahmon.html to fahmon1.html.
  • Change the fahmon.html file reference in the upload.txt to also reflect this different file name.
  • Advanced Option - View Multiple FahMon HTML Pages
(Only Needed if "Multiple Client Locations" is used)
  1. Create a new txt file copy the following Code
    Code:
    <html><head>
    <title>UserName - Folding@Home Stats</title>
    </head>
    <frameset rows="400,*" framespacing="0" border="0">
    	<frame name="main" noresize scrolling="no" src="fahmon.html">
    	<frame name="main2" noresize scrolling="no" src="fahmon1.html">
    	<noframes>
    	<body>
    <body bgcolor="#000000" topmargin=0 bottommargin=0 leftmargin=0 rightmargin=0 marginheight=0 marginwidth=0 style="font-family: Courier New; font-size: 10pt">
    	<p>This page uses frames, but your browser doesn't support them.</p>
    	</body>
    	</noframes>
    </frameset>
  2. Save and Close File
  3. Rename File index.html and upload to your web server.
    (Now, two FahMon pages will be displayed on the same page)
  4. You can edit the "<frameset rows="400,*" framespacing="0" border="0">" line to change the height of the top frame to better fit your client.
    (Example: "<frameset rows="500,*" framespacing="0" border="0">" or "<frameset rows="250,*" framespacing="0" border="0">"
  5. If you wish to have 3 pages listed at the same time, here is an example of the code
    Code:
    <frameset rows="400,100,*" framespacing="0" border="0">
            <frame name="main3" noresize scrolling="no" src="fahmon2.html">
  6. This can be expanded to as many pages as you want to display at a single time.
  • Advanced Option - Cell Phone Web Template & Viewing
(Allow for easy viewing on any cell phone with web access)
  1. Create a new txt file inside the Fahmon\template\ folder and name that file cell_template.txt
  2. Copy the code below into that txt file.
    Code:
    <head>
    	<title>Username Folding@Home Server Status</title>
    	TD {
    	padding:2px;
    </style>
    </head>
    			<tr>
    			</tr>
    				<td><center>@_PPD@</center></td> tpl//-->
    			</tr>
    			<!--tpl_loop <tr>
    		</table>
    	</div>
  3. Edit the "UserName" in line"<title>UserName Folding@Home Server Status</title>" to your F@H User Name
  4. Save and Close File
  5. Change file extension from txt to html
  6. Open the Preferences (Ctrl +P) in FahMon and select the "WebApp 2" tab.
  7. Go to the "Custom Web Application Template" option.
  8. Point that entry to the new cell_template.html file in the Fahmon\template\ folder.
  9. Now go to the "WebApp 1" tab
  10. Enable the Export Web Application Section
  11. Now point that entry to the FahMon\Upload\ folder and name the html cell.html
    (Example: Fahmon\Upload\cell.html
    (This is the same process used in Section 1 when setting up the original stats page)
  12. Hit okay and minimize FahMon back to the system tray
  13. Open the upload.txt file in the Fahmon\Upload\
    (This is the file created in Section 2 of this guide)
  14. You will need to add the MPUT cell.html line into the txt file.
    (Here is an example)
    Code:
    OPEN my.ftp.com
    mylogin
    mypassword
    binary
    MPUT fahmon.html
    MPUT cell.html
    BYE
  15. Remember as in Section 2, the MPUT line will need to be to the full file path
    (Example: "MPUT Z:\Fahmon\Upload\cell.html" or "MPUT C:\Program Files\FahMon\Upload\cell.html")
  16. Save and Close that file
You are done and your stats designed for phone viewing will upload the next time the script is ran by the task schedules. Simply go to that address on your cell phone and get a great overview of your clients with no extra data
End Guide
Publish Date: December 2008
Looks good Evil.
I'll give it a try today and see if I'm smart enough to follow directions :p
My kindergarten teacher said I'm not, but I'll show her.
I hope the guide is easy to follow and got you up and running.
Be sure to post your stat links up so I can check them out when they go live!
Great guide, could you pm me the edit version so I can add it in the [H]orde Guides for everyone to check ?
I got that sent to you.
Also, for those of you who have internet on your cell phones.
I am almost done making a template that is great for viewing on the smaller screen.
It takes a lot of the fields away, but give you a quick glance at yuor clients and status.
I will have Xilikon add it to the guide in a day or so as well as post it here.
Okay, I have added the Cell phone template and Viewing Instructions.
I tried it last night with several smart and non smart phones and the page looks really good.
No extra data, just client stats, name and PPD for a quick overview of your farms status on the go.
Here is my cell phone stats page - try it on your phone and see how you like it. File Size is extremely small (3.47K)
http://webpages.charter.net/evilalchemist/cell.html
I really want to hear when you guys get it up and running.
Is there anything like this for seti.
To my knowledge, not at this time.I would ask one of our WCG members here on the forum. Since they are also using the BIOINC clients as well.
I am sure with so many users, there are monitoring programs for BIONIC.
This setup uses FAHMON, a custom program designed to monitor Folding@Home only.
If you can find a monitoring program that will automatically create an html file every so often, then you can do something similar to what the guide describes.
Small Update to this Guide:
With FAHmon 2.3.99.1, a feature was added to FTP / HTTP your files to your site.
Export
These allow FahMon to create a formatted web page based upon a simple templating
system. Each of these 3 boxes will allow a separate page to be generated. These pages
can either be saved to a local file, or uploaded via FTP to a remote web server.
For FTP upload, a correctly formatted URL needs to be entered in the form
ftp://username:password (at) server/path/to/upload/file.html.
It also has the option to set the refrest / upload timer for local & web refresh.
This means you no long have to use the .bat method if you do not wish.
This feature works great ... thanks for the tip Evil.
