eVGA RMA heatsink issue.
Well, I got this card second-hand from someone and sometimes it gets weird video problems (such as pink video on important videos to me) and it did not come with the stock eVGA cooler. Specifically it has a NV Silencer 5.
Do they take back cards with aftermarket coolers? Will they give me the old cooler back? Can I just send it in without the cooler? Anyone have an eVGA cooler for sale?
NOTE: eVGA does not know it is a second-hand card :p
i'd just ship it and play dumb, be like "oh i thought you just wanted the card back, not the heatsink too"
although, thats not really honest
You sure it's the card and not a codec issue? Pink banding is a symptom of poorly configured / low quality decoders.
Try the same videos with VLC media player, as it's not DirectShow based and uses its own codecs. If they work fine then, your configuration is the issue, not your card.
In my experience FFDSHOW does this and similar things. While it's nice in that it will decode many things, the quality tends to be questionable. Try the Xvid codec (set to decode all supported formats) and Quicktime instead. Everything else should be supported out of the box by Windows Media Player.
GL Monty!!
Too bad the card I sold youis beginning to defect. Let me know if it gets out of hand, I will take care of it the best I can.
GL Monty!!
Too bad my card is beginning to defect. Let mek now if it gets out of hand, I will take care of it the best I can.
Well I really think it is a driver issue, because after just going into the color correction menu in the little tray guy it goes away, SOMETIMES. Using FFDSHOW and it does it in both quicktime and WMP. Also does it when I download the movies.
Try with VLC, also try uninstalling FFDSHOW and using the Xvid codec. FFDSHOW causes all kinds of problems for me. I know lots of people use and love it, but it's to the point that I refuse to install it, period.
if its that 7800 in your sig, turn down the damn clocks... if not, buy a new eVGA heatsink off ebay or something...
The clocks are fine, yes, even in BF2.(BF2, the ultimate stability test :D ) I just think it is a driver/plug-in problem, just seeing if anyone else had a similar problem.
Actually a pinkish or greenish screen when playing some videos is one of the classic signs that your G7x series GPU is clocked too far. But whatever...
I think I found out how to remedy it, I just switch from 75hz refresh to 72hz and it works like it is supposed to.
I call driver problems, even does it with the newest drivers.
