EVGA PS compatible with Silverstone short cable set?
Most likely, in my Node 304 build I used the PP05 kit PCIE and SATA cables with my Seasonic G450 in after continuity checking them twice. Seems I recall an oddity with the 24-pin Mobo connector, but always helps to have one those small PSU testers just to be sure.
EVGA Supernova 750 G2 is made by Superflower, the Silverstone Strider series was originally made by FSP I think (now Enhance).
The ATX24 cable is certainly not compatible, just look at any picture and you'll see why: 18pin + 10pin. The Sata is coincidentally 6 pin on both Supernova and Strider, but the pinouts are different, so that's not compatible either.
The PCIe and EPS cables are compatible.
