Hey guys, I have an eVGA P55 motherboard with 2 somewhat minor problems. First, upon startup the ethernet connection does not work and in order to get it to work, I have to go into device manager to disable it and then re-enable it. If I restart my computer, I don't need to perform the steps again but if I shut it down and then start it back up, I have to. Anyone else have this strange problem or know what to do?
Secondly, the computer won't go into sleep. The screen goes blank but the fans never stop whirring and the PC doesn't turn off. The display also doesn't return when you try to resume operation of the PC and I have to restart it.
I've updated the BIOS and drivers but that hasn't solved either of these issues. Any help is appreciated, thanks!
