EVGA NFORCE 680i shuts down
who am I - I ask
I think its the 8800 that shuts the pc down but i think the motherboard is also causing it
when i try and do a performance test it goes poof
i got the latest nvidia drivers for it
and ill have to flash it but i am not sure whats making it crash
any ideas
Another vote for power supply...the 8800 is a power hungary beast...If your using a 450w or 500w off brand then look there first.
Back probe the wires on the video card with a digital volt meter and watch the readings when the crash occurs.....
that certainly sounds like a power supply issue, although your PSU should be more than adequate for your hardware. maybe it's defective for some reason? i just went through two bad EVGA 680i boards, so it wouldn't surprise me if it were the board either. if you can, try another power supply... also as a courtesy it would help if you had your system specs in sig so ppl don't have to ask what hardware you're using (it isn't just to brag ya know ;))
hell, if you want to pay shipping, i'll send you my spare antec 450 for you to borrow for as long as you need to determine if the power supply is the problem. it should be barely enough juice for the job if you keep it cool...
its not mine so , with the power supply i put both plugs in it , correct? my ps has 2 i can plug in but wanted to be sure
yeah, both plugs... they weren't both plugged in already? i think the card makes this horrible screeching sound if you try to boot without auxiliary power.
It sounds like it could either be a power supply issue, as in it's possibly defective or something is wrong with your driver or OS install. Do you have another hard drive available where you can install a barebones installation of Vista or XP? You are running a "Performance Test" what test is this? Anyway, I would try a new install of whatever version of Windows you are running and test again to see what happens. I'm running an Evga 680i with an 8800GTX powered by an Enermax Liberty 620W. I had a reset issue in Vista when running the built in performance tests using the early beta drivers but gaming was fine. The 100.64 and 100.65 WHQL drivers fixed that problem for me. I never had any issues in XP.
