Brand APEVIA (ASPIRE)
Model ATX-AS520W-BK
SPEC ----------------Type ATX
Maximum Power 520W
Fans 3
PFC No
Main Connector 20+4-Pin
Dual +12V Yes
Power Good Signal 100-500ms
Hold-up Time >10ms at full load
Efficiency >70% under max range load
Over Voltage Protection YES
Overload Protection YES
Input Voltage 115/230 V
Input Frequency Range 50/60 Hz
Input Current 10A @ 115V, 5A @ 230V
Output +3.3V@30A, +5V@32A, +12V@35A, -5V@0.3A, -12V@0.8A, +5VSB@2A
MTBF 100,000 hours at full load/25°C
Approvals CB IEC 950/ TUV EN 60950/ UL 1950/ CSA 950
Features
Features Fan speed controller, full cable UV green Sleeves, 2.0mm aluminum casting; 1x 20/24pin Main Power, 1x ATX12V 4pin, 8x Peripheral, 2x Floppy, 2x SATA
This is the psu trying to run off a evga nf690i with a evga 8800gtx. Board lites up when psu is on but will not post or even turn any fans. Is this psu too small to even try using. I've switched out the 8800GTX for 6200turbo cause its the only pcie card i've got on hand and still does the same. I've try with 1 stick of ram a e6600 with pre9060 hsf from alpha. It showed post with the cpu video and memory, but I get nothing. I have one other psu but its running rig 1 in sig and I won't be able to swap and try it untill maybe monday (11/27/06) and I can't purchase something else untill after next friday. I've got a SilverStone ST75ZF in loaded in amazon for next friday. I've double check the connectors from motherboard to case (Lian Li g70) and tryed shorting the pins to see if that was it. Hooked up a pata drive and sata drive, same ol same no post, only thing I can think of is board is doa or psu is not enough. With all the new stuff on this board I think a eps v2.2 should cover all as aspire does not have 8 pin connetor or enough 6 pins for 8800gtx. Can anyone think of anything I might have missed. The last board I built was for a freand on 939 socket and I have not upgraded mine since socket 754.
Thanks.
Model ATX-AS520W-BK
Maximum Power 520W
Fans 3
PFC No
Dual +12V Yes
Features
Thanks.
