I am supposed to be doing a build tomorrow using the 7800Gt and free motherboard deal from newegg with a Thermalright XP-90 HSF and just found out that the backplate on the motherboard is incompatible with the XP-90.
A) Does anybody know if the backplate that came with my Asus A8V Deluxe will fit (I swapped it off when I installed my Zalman cooler).
B) A store that sells them in the Southern Rhode Island area.
Help!!!
Help!!!
