I recently bought an EVGA E758-A1 motherboard, i7 930, 6 gigs of OCZ ram (see below for full specs). I got everything set up and fired up the build and it doesn't POST, gets stuck on code 68 and tries again
So I start trouble shooting, and it turns out that DIMM port 3 is bad(so I thought), because it would post with a single stick in 1, and 5, but not 3. So I RMA it through newegg and get another board
Get it set up, and I get the EXACT same problem, port 3 is bad, will boot with memory in ports 1 and 5 just fine. Now I'm sure that the chances of getting 2 bad motherboards with the exact same problem is very slim, so I'd like to rule out that. The memory is good because I had another EVGA rig, and it boots just fine with all 3 sticks.
Could it be that the processor is bad or the motherboard needs a BIOS update to run with the new 930 i7? Gonna look at the evga BIOS update page and see if it says anything about correcting any problems for the 930
Id like to see if anyone else has had a similar problem or any additional troubleshooting I can do.
EDIT:
Updated the BIOS with the latest EVGA has. The computer now boots with all sticks in, but the BIOS only recognizes 4 gigs. Under computer -> properties, windows lists 6 gigs (3.99 usable). So it seems I'm getting somewhere...
CORSAIR Cooling Hydro Series CWCH50-1 120mm High Performance CPU Cooler -
EVGA E758-A1 3-Way SLI (x16/x16/x8) LGA 1366 Intel X58 ATX Intel Motherboard - Retail
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case - Retail
Intel Core i7-930 2.8GHz LGA 1366 Quad-Core Desktop Processor Model BX80601930 - Retail
ENERMAX Galaxy EVO EGX1250EWT 1250W ATX12V / EPS12V SLI Ready CrossFire Certified 80 PLUS BRONZE Certified Compatible w/Core ... - Retail
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3G1600LV6GK - Retail
EDIT:
