eVGA E-Leet Tuning Utility
Light1984
Anyone use this yet? I like the idea of having an all in one utility for tuning, except on the graphics tab, the only available option to tune is voltage (using v1.10.4). I find that odd considering I have an EVGA 680 GTX, if it was another brand maybe. Not sure why all the other options would be greyed out.
Thoughts?
I really like the ELEET Tuning Utility. However, I run a EVGA X79 Dark, so I can control the voltages on my motherboard as well.
Honestly, if you just want to control your GPU, I'd suggest using either PrecisionX or MSI Afterburner. You should be able to find a custom bios for your GPU to push it further, and MSI Afterburner to be able to push the voltages past stock. If you'd like, I could help you find a custom bios. :)
hey guys, thanks for the replies. Here is the link for the download, you have to be registered with eVGA though. I have had PrecisionX installed too, but it just seemed like their Eleet software would be an all in one.
http://www.evga.com/eleet/
