EVGA Classified - system won't power on
Thirteen
Hi guys, just finished my new wc rig and my system will simply not power on whatever I do. Here's the rig:
I'm quite certain the power supply is not the issue here. Could I have possibly damaged something when installing the EK block?
System specs:
i7 920 D0 (Heatkiller 3.0 LC)
EVGA Classified 3x SLI (EK fullboard waterblock)
6GB Patriot Viper II 2000mhz
Ati Radeon HD5870
2x 300GB Velociraptors (Raid 0)
1x 2TB Caviar Green
Corsair HX1000
Pull the MB out of the case, lay it on cardboard. Re-do ALL the connections, test.
Also try with a different PSU, try different RAM modules one at a time. Try a different CPU if you have one or can get another to test with. Try a different GPU. Try different components with a different system/motherboard. Try reverting everything to stock clocks and voltages if you have overclocked components in your system. It always helps to eliminate different possibilities on which component is faulty.
Unplug all connections from the power supply and do the 'paperclip' test. Bend a paperclip to bridge a connection from any black wire to the green wire on the 24 pin cable. Flip the switch on the PSU to on, if the fan in the psu spins up, the general circuitry of the psu should be functional.
Just curious, are you using the power button on the front of the case, or the switch on motherboard itself to turn it on? Because it might just be a simple matter of placing the power button cable into the wrong place on the board.
The switches were hooked up correctly, and I did try powering the MB on by using the on-board switch as well. I ended up rebuilding the system with a P6T I had lying around and it works just fine, so RIP classified.
Ah man that sucks...you're gonna RMA it, right?
Naw sadly I can't, lost the paperwork for the purchase when I was moving apartments so I'll be getting myself a new MB for christmas I guess, probably a Rampage II E.
