EVGA Classified 560 448 temps
Good evening,
I want to start this post of with my extreme appreciation for the EVGA Classified 560 448. It's an amazing card put simply. The only problem I have is that it's temps are high. High to what comparison? My previous card was a MSI 6970 Lightning that would temp in Battlefield 3 and SW:TOR (After settings.ini adjustments) to between 60-65C. The EVGA card is above 70+ and has, a few times, hit 80C.
To me this is pretty extreme. The card has extreme amounts of cool air to work with, sitting inside of a HAF X with all fans, including the 120mm that sides within the duct blowing air over the card. Does anyone else have temps this high with this card? I know the heat sink uses exposes heat pipes as cooling over the chip, but I thought that was supposed to increase heat transfer. Any suggestions or comments are welcome.
I have this card in my build. I have been playing Skyrim, Portal 2, and Borderlands at the highest settings and have had no problems with temps. Normally I run in the mid 50's to low 60's at most. This is in a Corsair 500R with an I5 2500K at base clock. My CPU temps normally run around 22 - 25 in games and 16 at idle.
Are you running the EVGA precision software with the ability to override the fans to run at different speeds at different temps?
