So I bought a brand new EVGA 9800gtx from newegg and it locks up after about 5 mins of play on WoW at full settings 1280x1024. It's not the drivers because I have installed Vista and XP using both drivers still with the same result. I called EVGA support and they said there hasn't been any problems reported like this yet.
I noticed my fan is consistently running at 30% and the card idles in Windows at 60C. I also know that it's not a heat issue because I've tried running the fan at 100% forced all the time. The temp stays anywhere from 35-48C.
Think I just have a bad card? What do you guys get with temps at idle/load? Do you guys see this problem in any other games? Do you guys see the problem in WoW?
