EVGA 9800gt running hot
Wraith 413
I have an EVGA 9800gt, dual slot cooler ( Not the Akimbo version), that I use for Folding@Home. It's been in the case about 2 months. Using Rivatuner, I have the fan at 100% and it still heats up to 73 C. My other temps in the case are in the high 30's-low 40's. Is there any other option to try, other than taking the cooler off and applying AS 5 ? Is anyone else having a similar temp problem with their cards?
You could try ducting fresh air to the GPU cooler's inlet. That's about the only thing I can think of other than swapping out the cooler with a 3rd-party solution. Watercooling would definitely take care of the heat :D
Is that really too hot? I know those nvidia GPU's can handle alot of heat. My 8800GTX idles at around 73C and get up to 80-81C during gaming. Never had problems with it.
Check if the heat sink is seated properly, also check the hairy/rubery inserts if they are still there between the heat sink and the components.
And then check for dust in the heatsink fins under the shroud. u be surprised how much dust balls collect in there over time and cause over heat.
I've been getting intermittent computer shutdowns and with the 9800gt showing the highest temp, I'm assuming that is the cause.My two 8800gts (G92) run about 56C @ 80% fan speed in my other computers while Folding, for comparison.
Checking the heat sink is my next task, when I get some spare time. :)
Thanks for the replies!
People who have ducted their PC's internals have noticed significant drops in idle and load temperatures on their GPUs, on the order of 5+C. Might be worth a try :)
Thats the same as the 8800GT SSC.
I have 1 of them in a very NON-well ventilated case & stock EVGA Single Slot Cooler.
45-55C Fan speed at 30% Idle,
65-75C 30% in game (Mirrors Edge)
55-63C 80% in game (Mirrors Edge)
(Sorry this is about the most graphic intensive game i have ahhaha)
The temp itself isn't alarming as HAXOR says
but he is running the card at 80% fan and its at 73C already.
So imagine if that card be running the fan at 30-50%, so it is a bit alarming, i would be too.
Again, thanks for the replies. The other reason I posted here was to see if other people with the same model card were getting similar temps.
Hazor- It's a dual slot card, not single slot. Just for clarification.
